sebmeca
ERROR ID 51 et 54 UNRECOGNIZED OPTION IN LINE : /ALTDOCTDAG
Hello !
I  have a problem when i start my simulation from hypermesh Radioss interface ( student edition 2019 ).
My  simulation tries to simulate a quasi-static compressive test on polyurethane foam.
When I run Radioss, the first error ID 51 appears :
.. BLOCK FREE FORMAT
ERROR ID :    51
** ERROR IN INPUT OPTIONS
DESCRIPTION :
   /ALTDOCTAG
Then, during running I have a lot of error ID 54 :
** ERROR IN INPUT FORMAT
DESCRIPTION :
   IN BLOCK : /ALTDOCTAG
ERROR ID :    54
For me it's a problem of the version of hyperworks used because at the beginning I have imported geometry and mesh from a file which I don't know the software version.
But I'm not very sure.
Unsupported cards gives me this :
## File: C:/Users/Sebas/Documents/stage_mousse/modele_eric_modifv2_0000.rad, Line: 4228 -- The Keyword listed below is currently unsupported
# func_ID1  func_ID2  func_ID3  func_ID4  func_ID5
#           Fscale_1            Fscale_2            Fscale_3            Fscale_4            Fscale_5
#          Eps_dot_1           Eps_dot_2           Eps_dot_3           Eps_dot_4           Eps_dot_5
## File: C:/Users/Sebas/Documents/stage_mousse/modele_eric_modifv2_0000.rad, Line: 4237 -- The Keyword listed below is currently unsupported
#-  5. UNSUPPORTED CARD:
/ALTDOCTAG
U[ljU5^P3QoPMS080`2MHCDdFjM9g]mp2Jb2@hkHQ6Y6Q8B6eFmSE1]dqAGeRNVKfZ@89h;SYm]Vdf:1J`fQYNn789K5j\DEIMJF
THANKS IN ADVANCE FOR YOUR HELP !
modele_eric_modifv2_0000.out modele_eric_modifv2_0000.rad modele_eric_modifv2_0001.rad modele_eric_modifv2.hm
To fix this problem, you can delete the Unsupported card in HyperMesh in the model browser, Cards, Unsupported, right click and select delete.
I'm not sure why the /ALTDOCTAG is showing up as unsupported.  It is a HyperMesh only card that Radioss does not need.
Thanks,
Andy
sebmeca likes this
