Sign in to follow this
sebmeca
Problem vizualisation stress results on Hyperview Radioss Results
Hi !
I have a problem when I try to vizualise Radioss results on HyperView.
My model is a foam box under a compressive uni-axial test.
During Radioss execution I have no error and warning but when I try to vizualise stress or forces into foam box , I see Stress or forces are egual to zero ....
However, deplacement results are not equal to zero and seems correct
I attach my model and h3d file
Thanks in advance for your help !
modele_eric_modifv5.hm modele_eric_modifv8.h3d
I think there are a few issues in your model you need to fix. At a glance, your INTER/TYPE7 has a set gapmin of 0.1. This implies that anything within 10 cm of your impactor is in contact with it. Meanwhile, your impactor starts only ~1 mm away from the foam, which implies your impactor is penetrating 10 cm into the foam from T=0 seconds.
Unfortunately my solver is currently bogged down with some other work, so I can't play around with your model. Make sure you read up on TYPE7 Interfaces in the reference manual. I recommend gapmin to be 0.1*(smallest 3d elem edge length) as per recommendations in the manual.
sebmeca likes this
