Sign in to follow this
RodrigoPadilla
Motion Piston Sim
Good Evening, im writing to ask for support in this simulation once again, I made the setup in Hypermesh, and im trying to make the surface calles piston to move towards the outflow surfaces defined in the model. I´ve already set up a piecewise linear function multiplier for this translational movement and everything but the faces dont move properly, made one model with no gap between the walls and the faces and another one with gaps so the faces are disattached to the walls with gap parameters defined but it doesn´t work, i leave the models attached so somebody can check them out and give me some pointers.
Thanks a Lot.
If you can attach the .inp and MESH.DIR (or HYPERMESH.DIR) maybe I can take a look at it.  You should also contact your local Altair Support Team.
This will likely require you to communicate directly with your local Altair Support team.  In which country are you located?  Are you using the Student edition?  Or - are you using paid HyperWorks Units?
