Sign in to follow this
Crashphys
Composite thickness increasing stress??
I am modelling sandwich panels applied to a wall with loading in various cases. In sandwich theory, the stress should decrease with core thickness. However when the core is thick here, the minimum principal stress is much higher than when the core is thin.
I am aware there is a high load specifically at this point in specific so stress is high, however stress should still decrease with increased thickness. I am wondering if anyone has an explanation to help me understand?
Thin Composite:
Thick Composite:
forum.zip
These counterintuitive results can be explained if the displacements are imposed: the thicker structure is stiffer and develops more stress under the same imposed displacements.
For similar reasons when optimizing for stiffness:
-imposed loads= minimize compliance
-imposed displacements= maximize compliance
Crashphys likes this
Hi Simon,
Thanks again for the help. In this case, loads are applied and not displacements. That's what makes it all the more confusing...
Worth mentioning also: For all load cases, compliance appears to increase with increased core thickness.
Hi Simon,
I guess this is not so much a software problem but a theoretical one but:
Considering there are both loads and displacements applied here, if I wanted to optimize this is there a way to address this if I wanted to run OS optimization with stress constraints?
I haven't done breakout model optimization yet so take this with a grain of salt:
One way coupling is a limitation of breakout modeling: the boundary conditions transferred from the global model may not be valid in a local model, if the local model's stiffness is changed significantly (in a way that alters global behavior).
Check how the global response changes at upper when compared to lower bound stiffness (thickness). Afterward, perform optimization with a narrower stiffness range for which boundary conditions are still valid.
Also try including a more extended transition region.
You may find the following article useful:
https://www.digitalengineering247.com/article/global-local-modeling-fea/
