Hello! I'm approaching PyFlux to build a geometry for simulating a magnetic bearing. I've already built the geometry through the Flux user interface. Does Flux return a PyFlux code linked to what I've done through the user interface?
Thank you very much!
Hi Salvator,
Yes, you can find all the command in a file in the working directory :
Flux3D_log.py  if you use 3D module
Flux2D_log.py if you use 2D module
You can also find it in the .FLU repository (in "persistent" repository)
Yann
