When I run this command using below tcl
hv -b -tcl Image_Capture1.tcl example.modl example.res
This is the results log I see on my linux terminal:
Ready
Loading Report...
Applying Report...
Ready
Ready
Capturing...
Ready
It's stuck at "Ready" and unless I press Ctrl+c or enter it doesn't exit back to terminal. How can I make the code to exit to terminal after the proc is over?
proc BatchMain { } {
set inputdeck [lindex $::argv 6]
set resultfile [lindex $::argv 7]
puts $inputdeck
puts $resultfile
set t [::post::GetT]
hwi GetSessionHandle sess$t
sess$t GetProjectHandle proj$t
hwi OpenStack
sess$t LoadReport Batch_Process.tpl
sess$t ApplyReport Batch_Process replace true false 2 $inputdeck $resultfile
set numpages [proj$t GetNumberOfPages];
for {set i 1} {$i <= $numpages} {incr i} {
proj$t SetActivePage $i
proj$t GetPageHandle pg$t $i
pg$t Draw
pg$t ReleaseHandle
hwi CloseStack
proj$t ReleaseHandle
sess$t Close
BatchMain
