alpha
How to check time-step in SL(Radioss/LSdyna)?
I am running some drop test for electronic cover parts (Radioss).
However, I have not found any tool to check time step in SL.
May I know your advice on this?
Thanks
In HM, after assign Material or Property for my parts (2D & 3D), I can check the estimated time step. But I do not know how to do in SL.
This is very important function for impact analysis to reduce computation time.
399901607_nh.thumb.png.e60b6637ffd24f6faed0f96a1d5f8113.pngHope this is clear for you.
Hello Alpha
Thanks for your explanation.
Currently in SimLab you can check the time step using the Quality Check tool from Mesh > Verify > Quality.
After applying Material & Properties, select the bodies and check the time steps based on the appropriate element types.
Kindly let us know if you have any concerns.
Thanks & Regards
Nantha Kumar N
