1 hour ago, Adriano A. Koga said:
the same video i've shared before for rigids shows how to create beam elements.
you should find something in Altair University or their youtube channel.
for your model, having only the disks geometry modelled into the CAD is enough, including the points for attaching the beams.
In HM you will create first the 2D mesh, using the fixed points as reference.
I'm attaching a very basic video as well, but again, go after some training material in Altair University.
Would you be so kind as to let me know how did you create these circles at first ,  I promise I will go through training for hypermesh !!!!  I spend  much time working on it through soldiworks but it did not work but based on that video , hypermesh can properly do it . again I would be so grateful . honestly  you helped me a lot . thank you so much  .
6 minutes ago, Adriano A. Koga said:
if you have solidworks, just draw these in SW and then import them to HM. It would save you some time.
In HM follow the attached video.
and how can we create that  cylindrical beam which goes through  the center of the four disks you created, would you please help me create that robot and try to apply a force on one of the cables and see the bending of that robot. help me with video tutorials as you did before. Thank you so so much Mr adriano.
it must be a hole in each disk to place the cylindical beam.
On 6/10/2020 at 9:42 PM, selman djeffal said:
Oki , thank you so much
unfortunately , it did not work out and I have abondoned the idea of using hypermesh , anyway, thank you so much Mr adriano for your time , consideration and help . may  god bless you
Adriano A. Koga likes this
7 hours ago, Adriano A. Koga said:
unfortunately you've started with a model that is not so trivial, as it is a NL problem.
And having no experience with HM makes it a little bit difficult to start with this problem.
I would recommend you to go slowly...crawl, walk and run approach.
Exactly Mr adriano. I wish one day you can make a tutorial about those continuum robots. ( flexible structure ) in hypermesh.
I came back again , I have finally found the solution , I just need to draw a pre-curved beam  and mesh it using nodes , is it possible to create a pre-curved cylindrical beam as show in the picture below .
waiting for your answer Mr. adriano
10 minutes ago, Adriano A. Koga said:
you can import the geometry or create it in HM.
I'd say that creating this geometry in Inspire is easy.
But again, you will need to spend some time to learn the basics of HM for building these analysis.
thank you so much Mr adriano , I have started learning it and I am amazingly improving. but  sometimes I come across ideas which does not exist in tutorials.  this is why I turn into your help.  the beam you created is hollow ( empy inside)  while  must be full and I have to delete that additonnal node which stands alone !!!
having a complete torus surface, you just need to create a solid using the 'solids' panel.
just make sure to have the surfaces enclosing a volume.
just reviewing my video before, there's no need to create the larger circle that I did. I was thinking to use the 'drag using line', and ended-up not using it.
selman djeffal likes this
is it possible to make a beam full inside and delete that circle with its node !!
even its node can be deleted , I mean the node of the large circle !!
24 minutes ago, Adriano A. Koga said:
after having the solid torus created, you can delete all the rest.
the last question Mr adriano , how can I make this beam full and delete that node which stands alone  !!!
it is very important to have your answer , it is the last step before I apply the follower force.
I am very thankful Mr adriano.
12 minutes ago, Adriano A. Koga said:
your surfaces are not closed.
You need to create surfaces for the caps of the tube.
after all, just delete what is not needed and for the temp nodes, use the geom>>temp nodes to clear all temporary nodes.
Mr adriano , you can not imagine me how I am thankful.  hypermesh is a great software and you are a great supervisor .
would you please have a look at my file , i have an error (fatal error)
followerforce.hm
