alpha
Unable to convert to penetration (intersection)
I am try to use Intersection command to convert GAP/OVERLAP to penetration. Then I do BOOLEAN later.
However, I am unable to do?
Anyone knows how to use this command?
Can you turn off "Near by surfaces not overlapping" and "Penetrating surfaces" check box and then try convert to overlap? It will work.
Refer the attached video for your reference. Also, attached a sample model used in the video.
Intersection.gda
alpha likes this
