i am performing a topographie optimization of a hat-shaped beam unter 3-point-bending with HyperMesh and Optistruct.
My aime is to minimize the compliance beneath a certain value (objective minimize compliance, constraint compliance < 14000), without exceeding a certain mass (constraint m < 0,000553)
In the optimization controls i have limited the maximum number of iterations to 100 and the convergenze criterion to 0,000001.
When i start the optimization, optistruct only performs the inital analysis and one optimization-iteration. The compliance of this one and only optimization-iteration is lower then the inital compliance but higher then the desired compliance. Why does optistruct dont perform additional iterations?
Thank you very much for your help!
With kind regards
Tim Winkler
i found out that the problem was a high mesh distorsion due to the bead creation.
My solution was a better and coarser mesh in the design space and other bead parameters (bigger minimum bead width and a smaller bead angle).
Thank you for your attention
With kind regards
Tim Winkler
