Sign in to follow this
Linux34
Cell-Mesh Error by usage of SPH-Method
Hello everyone,
i generated a model with the nFX Tool SPH-Particels with the Particle spacing 1. The Solver nanoFluidX had no problem solving it.
After that i changed the particle spacing to 0.5. But now the solver ist having issues. Before the simulation starts the following problem occurs:
I have also tried to remove Duplicate nodes but SimLab isnt finding any.
Has anyone an idea what the reason for this error could be?
Thank you!
It’s difficult to say from the screenshot , but from the description I’d guess it’s one of these things:
  • His model particle size does not match the value in the .cfg
  • Or exported mixed size particle bodies from SimLab (SimLab will export what’s displayed at the time).
Could you please share the full output file and .cfg, this will help us to narrow down the issue.
KamalRaj
If I also may add - it might also be that there was a gross error during pre-processing resulting in excessive overlapping particles in a certain location. There is a tool in SimLab which allows you to check "duplicate particles".
