Sign in to follow this
Jerome Teoh
Automated simulation
Is that possible to run multiple simulations with different inputs (especially material properties) in Altair Flux with the python interface automatically?
I wish I could code, for example 'for loop', that I can change the inputs and export the simulation results into excel or txt file.
Jerome.
Hi, Yes, it is possible to do it in Flux. There are two ways to do it:
  • You can use a batch mode. In this case you will prepare all the Flux project.
  • You can use a python script, in this case you need to create a script allows to change the proprieties (physics, geometrical) in the model. You will find attached a document about the python script. This will help to create your own script.
Best regards.
Altair_Memento_pyFlux_GB-v2.2.pdf Altair_Memento_python_GB-v2.1.pdf
