Sign in to follow this
Jerome Teoh
Solver not correctly converged.
I did induction heating simulation in Flux2D .  I  try to define my substrates from isotropic to anisotropic on resisitivity - which means the Y-direction value become much smaller.
Then I hit the solver but it says the it is not correctly converge. What can I changed to make it happen?
Best,
Jerome.
Can you try to change the solver. To do it:
Solving ‘in the top’ >> select solving process options >> edit >> select nonlinear systems solvers >> method for computing….. (select another method of solving, for example Fujiwara) and solve again the project. If the problem, persist can you share the project?
Best regards.
