Sign in to follow this
Linux34
Postprocessing from SPH-Model in Paraview
Hello everyone,
i hope i am not wrong with this topic here.
When I export my SPH-Model from SimLab to .cfg and .txt file there is the option to export the stl file for the motions.
When I load the .cfg File in paraview it finds the stl file and the parts are visualized. But when i hit play and want to see the motions (in this cas the rotation of to gears) nothing happens.
Does anyone know anything about this issue?
Thank you very much!
STL_GEOMETRY.zip Gearbox.cfg
Hello. I have noticed that your entire case seems to be in meters. That means that your dx = 1 [m] and that your domain spans from -180 [m] to 460 [m] in y-direction, implying your gearbox simulation is operating on a kilometre scale.
Now, I imported the stl files you sent in ParaView and noticed that their scales are normal, meaning spanning approx. -0.15 [m] to 0.4 [m]. Your motion definition in the .cfg file is also in [m], with the center of rotation for one of the gears being located at coordinates (-256.153, 249.956, 49.9558) meters.
Basically it is very likely that this scale discrepancy is causing you some trouble.
Hope this helps.
