Sign in to follow this
Nik
How to assign 1 property per 1 element in Hypermesh?
Hello all.
I have a model with properties assigned to groups of elements: 1 property per several elements.
Is it possible to split these properties as follows:
1 element - 1 property.
Element ID = property ID.
I suppose it can be done using some scripts.
Or even the way using Excel import \ export will be helpful.
it would be possible to create a script, for that, but maybe excel or some text editor would be enough depending on what you already have.
I'm attaching a similar script, not completed, that does something similar to your request, if I remeber correclty..
properties_breaker.tcl property_divide.tcl
On 7/3/2020 at 9:13 PM, Q.Nguyen-Dai said:
How many elements do you have in your model?
~8000 elements and ~100 properties
On 7/3/2020 at 9:41 PM, Adriano A. Koga said:
Thank you.
Now I can split all properties in a way that each element has its own property.
So I have like 10000 properties. This is what I need.
But I still don't know how to assign to each property ID of an element inside this property.
Now I have Prop ID = 1 with Element ID = 2000 in it.
My goal to have Prop ID = 2000 with element ID = 2000.
If you want to assign property ID=2000 to element ID=2000 AND if all properties exist already, use my following code:
*createmarkpanel elements 1 "Select elements"
set elemList [hm_getmark elements 1]
foreach eid $elemList {
    *createmark props 1 $eid
    set propList [hm_getmark props 1]
    if { [llength $propList] == 1 } {
	   *setvalue elems id=$eid propertyid=$eid
    } else {
       puts "Prop ID=$eid does not exist!"
It's almost what I need, but I have 2000 elements in ID range 10000 - 12000 (example) AND 2000 properties with ID range 1 - 1999.
Element #10000 has property with ID = 23.
Goal is to renumber current element property with ID of the element.
You can use "Tool" => Renumber => Property,
but this automatical method is dangereous and you can get wrong results with element.
What's the difference between Prop 1 & Prop 2, shell thickness? Your elements are shell type?
I have 3 elm types.
Crod/Cbar and Cshell.
I did try Renumber tool, but in my case it's too time consuming to renumber properties 1 by 1.
As I can see the process:
1) choose element
2) check the property assigned to this element
3) now we have element ID and property ID.
4) set property ID = element ID - where I stuck.
But, as I understand there are 2 ID types in HM: solver ID and HM internal ID.
I tried *renumbersolverid properties 1 $elem_id 1 0 0 0 0 0 as it in command.tcl, but it doesn't work properly.
In nastran, PID is equal EID by default if you don't assign property to element
Don't use *commands in long 'for' loops, use 'puts' to write property cards to a file then import that file, it just takes a few seconds.
Ok. Thank you for the help.
I did what I want.
My script is attached.
1) choose element
2) store elem ID and prop ID
3) create new property with PID = EID and Pname = EID
4) update new property with stored data from old prop
5) assign new property to element
props_split.tcl
