Sign in to follow this
apallaprolu
Material Database Excel Sheet
I have recently started using WinProp/WallMan/ProMan for modeling some indoor scattering scenarios and wanted to know where I could find the excel spreadsheet which had the material properties listed for empirical parameter calculation (as stated in the manual below).
I have looked through the installation directory but did not find any .xls, .xlsx files. Would be great if someone could attach a sample.
Thanks in advance!
Anurag.
for the 2020 release the corresponding material sheet is in Example-A03-Database_Materials.zip which is located under:
C:\Program Files\Altair\2020\help\winprop\examples\ExampleGuide_models
for the 2019 release the corresponding material sheet is in 05_Database_Materials.zip which is located under:
C:\Program Files\Altair\2019\help\winprop\examples\
Ring and apallaprolu like this
