vishitej
SRM Motor Coupling with Activate
Hello All
1. I Would like to couple my SRM Machine model in Flux  to Activate to perform a closed loop simulation using a look up table approach which is given in a document " Switched Reluctance Motor Multiphysics simulation".
Can any one provide the Activate blocks shown in the example ??
2. I would like to do a electromagnetic simulation where the motor should be started with a load (torque). Is it required to include moment of inertia of the load as well ?
3. I would like to compute efficiency map of the motor. Are there any python scripts available ?
Multiphysics_Modeling_of_Switched_Reluctance_Machine_(SRM).pdf
Hello;
You can find the Activate project, in your Flux installation directory, for me i can find it here:
C:\Program Files\Altair\2020\flux\Flux\DocExamples\Examples2D\Cosimulation\SPM_Regulation_Activate\SPM_Regulation_Activate.zip\SPM_Regulation_Activate_Case1
Regards
