zainab
Convergence Problem
hi dears,
i make two designs of induction motors , with both design i have problem of convergence, i can not know where is the error, please can you check them and help me?
1.rar 2.rar
Can you modify the solver used in your project. To do it:
Solving >> solving process options : select edit >> select nonlinear system >> select method for computing the relaxation…  modify the method used (use for example optimal method ).
Best regards.
i used optimal method and the problem of convergence is solved but my results have error, the torque is very small and nagative. Are there any advice to solve this problem? thanks.
