Sign in to follow this
Kishore_c
TCL Script for element and nodes
Hi
I need to create element and node set for displayed components.
Example: Having 10 component, so for each component there should be set(node and element) with name correspond to component PID followed by ND & ET.
PID Name: Thickness_2.5mm
then i need node entity set with name Thickness_2.5mm_ND & Thickness_2.5mm_ET.
Any leads or help ?
Thanks
Kishore
