Sign in to follow this
Norasapocin
Stress results not showing in Hyperview
Hello there,
I am trying to simulate the residual stresses and strains of a composite panel after a temperature change to evaluate the springback. To do so, I am using HM as the pre-processor and HV as the post-processing tool, and MSC Nastran as the solver. I am currently running SOL 400 (non linear implicit) analysis and I get my OP2 file and f06 just fine. When I load my results (bdf and op2) in Patran I can see them fine, but when I try to do so with HV, I can only visualize displacements and SPC forces but not Stress or Strain. It seems as those results where not loaded into HyperView. What can I do to solve this?
If it helps, here is the beginning of my bdf file.
SOL 400
CEND
$$                      Case Control Cards                                      $
SUBCASE 1
 STEP 1
  ANALYSIS = NLSTATIC
  NLSTEP = 1
  SPC = 2
  TEMPERATURE(INITIAL) =        4
  TEMPERATURE(LOAD) =        5
  DISPLACEMENT = ALL
  ELFORCE = ALL
  NLSTRESS = ALL
  OLOAD = ALL
  SPCFORCES = ALL
  STRAIN = ALL
  STRESS = ALL
$$                      Bulk Data Cards                                         $
BEGIN BULK
PARAM NOCOMPS  1
PARAM PCOMPRM  1
PARAM SRCOMPS  YES
PARAM    POST    1
PARAM  LGDISP  1
PARAM   PRTMAXIM YES
NLSTEP  1
My MSC Nastran version is the 2016 one and my Hyperworks version is the 2019.0.0.70.
If it helps, I have tried to use the CSTRAIN/CSTRESS cards as output requests but they seem to not work in Nastran.
Thanks in advance.
