Debdatta Sen
Understanding the output of 'gettypelist'
Using the attached script, I request the data type list present in the d3plot File (also attached:Bumper.7z), and I store the first element in a variable.
I would like to comapre it with an input string.
Apparently the dimensions are different:
Does anyone have an idea what I am doing wrong?
I am not sure what type is being returned by the command 'gettypename'.
I presumed it should be a string, which I could compare with other strings.
Best Regards,
Deb
Bumper.7z dataType.oml
Hi Debdatta,
the if statement "dataTypeName==search" compares number of characters in both variables.  That's the reason why the error raised.
Instead use "strcmpi" which compares the characters itself in variables
if strcmpi(dataTypeName,search) == 1
% 1 == logical yes if both variables are identical
    printf('Stress result found!')
end
thanks,
Manoj
