Sign in to follow this
walid guendouz
Flux 2D
hi everybody, please I have a 2D flux simulation problem I have powered my permanent magnet synchronous machine with a three phase voltage source one with a good voltage phase shift. according to the results I got a torque with more than the nominal torque and the currents are very high values.
ecause someone can help me thank you????
In the case when you sue a voltage source you need to use several periods (more then 5 periods). The reason that you get a Hight value of the current is du to the fact that you are in transient regime and not in steady state. To reach the steady state region you need to increase the number of period that you use in the solving scenario.
Best regards.
