Sign in to follow this
MotionSolve optimisation
I'm running an optimisation on a mechanism using Hyperstudy. I'm starting Hyperstudy from Motionview and using Motionsolve as the solver. I can get the optimisation to run etc. and the results are fine, but I need to 'press any key' in the Motionsolve window after each iteration. Is there any way I can avoid doing this? Do I need to run in batch mode, and if so how do I do this? I've looked at batch mode through the Job Management options, but the batch option is greyed out??
For those who are interested, I've figured this out. I had to use the 'Motionsolve_HSt' solver in Hyperstudy rather than the normal Motionsolve solver. The HSt solver is specifically for Hyperstudy and doesn't require any user interaction at the end of each run. I'm running this on XP and I also had to make sure that the directory structure being used for the 'Study directory' doesn't contain any spaces, or else the thing would crash.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
