Sign in to follow this
Cya
Increase memory allocation for HyperMesh
I have a problem with HyperMesh.
It uses only 900 Mo of my RAM (and can't go further) while it would be useful to use more for some operations.
So, I would like to increase this limit level. Do you have any ideas to do that ?
Thank you !
Cya.
"Radioss/optistruct" memory options are for SOLVER, not for your Hypermesh session.
IMHO, Hypermesh uses memory automatically when needed. You say your Hypermesh uses ONLY 900MB? Maybe your model needs only that quantity of memory? How about your model size? Do you try any bigger model yet ?
Sometimes, my Hypermesh's session uses some Go of memory (overs my 20Go physical memory).
16GB of ram is NOT small at all for a workstation. If your Hypermesh is slow, I think RAM is not the cause.
What about your graphical card ? Your OS ?
Hi Mechanist,
What is the version of HyperWorks you are using?
May be you can check if the graphics drivers are up-to-date...
On 18.02.2016 at 4:36 AM, korence said:
I have the same trouble with you in serveral days ago, but now it is solved in easy way.
Hello korence,
How did you solve this problem? Could you please explain me?
Thank you in advance
